Side cover repair?
Everything else on your bike.
mycactus
What Bike or Bikes Do You Own?: 34L
Side cover repair?
Post by mycactus »
Hi there, this is my first post here. Just trying to figure out is it possible to repair/replace the fasteners on the plastic side cover. I've a side cover with all of them popped off but considering the price of a replacement side cover...
I was thinking maybe it's possible to make a mould of a fastener from the other side with something and then secure it in place? I was considering trying fiberglass as the body of it and maybe a nail or screw at it's centre, but how would I make the mould?
Any info appreciated! Thanks...
Pictue here: Image
(It's not coming up in the preview post, you might have to click on it)
Actually, here's the link to it https://www.dropbox.com/s/20evzr1mhrgkf ... .32.19.jpg
tall-mike
What Bike or Bikes Do You Own?: 1989 yamaha xt 600 enduro
Previously Owned Bikes: 650 yamaha
kawasaki 500 triple
suzuki 800
yamaha 80cc
yamaha 55cc
mini-bike 2.5 hp
Re: Side cover repair?
Post by tall-mike »
Looks like a bolt and a couple of nuts to secure to the drilled out pin , then grind the bolt head to secure to the rubber grommet on the frame. Mike
Bernieboy
Post by Bernieboy »
I had the same problem. Got some aluminium pins machined up with a flat base to match the location on the inside of the cover. Smoothed with sand paper and stuck with super glue. Worked great and does not interfere with he outside of the cover
You should sell them pins Bernie........ I'll have some slywink:
