34L Tank Needed.... or advice
xpag6259
What Bike or Bikes Do You Own?: Triumph Speed Triple 1995
Yamaha SR500 1978
Yamaha RT3 1973
Yamaha RT3 1973
Yamaha XT600 Tenere 1983
Yamaha TT600 1984
Previously Owned Bikes: Ducati 860GT
Suzuki GSX 250
Yamaha XJ900
Kawasaki GPZ
Yamaha CT3
Post by xpag6259 »
During my recent trip the baffles in my tank went from slightly rattly to louder than the exhaust note. I'd first thought that they probably come loose where they're spot welded to the base of the tank. Now I think some of the 'wings' have either vibrated off or torn badly. Has anyone ever taken a tank apart and seen what goes wrong? I have thought of cutting a hole in the section that the seat covers.
Or better still, anyone want to part with a decent tank. Doesn't have to be perfect, just have good baffles. I know its a long shot, ...............
paul
so many projects, so little time
Re: 34L Tank Needed.... or advice
Post by Eric66 »
Hi Paul, a very long shot to find another tank,I would cut her open in the same spot and have a look-see.You should have enough room to tack weld the baffles back in and weld up the hole but I would then give it the POR15 treatment for good measure.
You could just try pulling them out through the filler neck? :dunno:
If you had to chop a hole do it from the underside of the tank (the frame tunnel) thats how most tanks are repaired.
55W1985
What Bike or Bikes Do You Own?: XR 650L 1994,XT 600Z 55W 1985
Previously Owned Bikes: CX 500 1981,R-80G/S PD 1987
Post by 55W1985 »
On my tank there are several cracked or partially loose.By painting the inner side with that epoxi paint and bending those with a wooden stick to a position it wouldn´t move any more that problem is long gone.
XR650L(1994) 55W (1985)
