I've got an 88 Xt600Z with a 3AJ engine, been sitting untouched for a while but lately, I've begun work on a rebuild.
Most of the way through pulling down the engine for inspection etc, and just as I've gone to split the case I've noticed that the flywheel side case is stamped "1VJ" which seems odd to me as I was under the impression that the 1VJ engines were from a previous model Tenere.
The cylinder head is clearly marked 3AJ, the compliance plate states it as an 88 model and the frame number, while hard to make out starts with "3DE" which I thought was exclusive to the 3AJ series. (Could be wrong, I'm new to Teneres and Yamahas in general) The final giveaway is that the instructions for splitting the case in the 3AJ workshop manual I have show things just a little differently to what I have on my bench.
So I'm assuming that at some point in time, the bottom end has been replaced and the 3AJ and 1VJ are compatible. Was this common?
What I'm hoping for is for someone more experienced to confirm this for me, and also some information on the 1VJ engine. Is there anything imparticular I should be looking for? Or should I be looking for a genuine 3AJ replacement before I put it all back together?
Cheers for any help.
Pat.
