Danjets Honda Transalp
Re: Danjets Honda Transalp
Nice one, same here im glad you never started yanking the heads off.
:campfire:
Danjet600
Post by Danjet600 »
ok a little premature with celebrations it seems i also have the dredded CDI problem, it fires randomly, but now with the wire fixed it behaves as stated in the threads i have read, the tacho dosn't work when the CDI's are swapped, so new CDI's will be ordered, for now i'm trying the home repair by resoldering the circuit board in the cdi, works for some people, one bloke soldered the circuit board then hard wired the CDI's to the harness :eekers: , no further problems for him so far
Murray Walker
Look for cracked or dry joints Danny, just touch your iron on them & the existing solder will join again.
MEZO wrote:Look for cracked or dry joints Danny, just touch your iron on them & the existing solder will join again.
I would recommend also adding some fresh flux cored solder or else you wont get a nice "wet" joint.
Danjet600
Post by Danjet600 »
just went and got one of these
:nod:
http://www.jaycar.com.au/ShowLargephoto ... ME=20/130W Soldering Iron Starter Kit&IMAGE=
now i can suck out the old solder and redo all the joints :wink2:
:pleasesir: hope it works
Murray Walker
Yep they work very well "solder suckers" they also work well on spots/zits blackheads etc.
Yeah, and don't get the trouser python caught in the industrial sized model. :lol:
Danjet600
Post by Danjet600 »
ActionManMelb wrote:Yeah, and don't get the trouser python caught in the industrial sized model. :lol:
and where do you purchase these industrial sized models? :blush:
this is the before my resoldering job
and after :bigeek:
went a bit crazy and bulked up the solder but fuck me it works :lol:
firing on both cylinders and tacho works with CDI's in any position, now I've got to seal the circuit board with some resin or something any idea's??
Murray Walker
Dirtybrit
Post by Dirtybrit »
Try using the stuff you get out of the industrial sized sucker! :lol:
Danjet600
Post by Danjet600 »
Dirtybrit wrote:Try using the stuff you get out of the industrial sized sucker! :lol:
:funnypost:
well i end up using some araldite, should be protected now
the location of the CDI's in the early models are verticle and the seat pushes down on the plugs and causes problems
in the later models they mounted them sideways, so i copied the setup
some progress was happening
i got to the point of starting it up and had some success, but was misfiring a bit and seemed really rich, i adjusted the carbs tried everything still no joy so left it for the night, next day went to see if it would start and it wouldn't turn over :wtf:
so i pulled the spark plugs and found no.1 full of fuel :bigeek: so pulled the carbs off again, and found the float stuck :headslap: got on the net found how to set the float level properly, went through both carbs again.
refitted carbs went through the final checks, water yes ,oil?? :foot_tap: whole sump full of fuel :pissed: so i had a stuck float and my fuel tap dosn't stop the fuel in the off position, and i had put 5lt of premium fuel in which is now mostly mixed with oil :sadnanna:
so i've drained the motor oil/fuel out took off the oil filter and left the sump bung and oil filler plug out hoping all the petrol will evaporate, is there anything else i should do? i'm thinking fill it with cheap oil get it hot and drop it out? thats if it runs :lol: don't want to get ahead of myself i seem to be taking 1 step forward 2 steps back at the moment
Murray Walker
