Same as the 3AJ i would imagine? (same motor) download the 3AJ service manual HERE.
Diagnosing a lovely knocking noise
Re: Diagnosing a lovely knocking noise
- Founding Member
- What Bike or Bikes Do You Own?: 7 x 3AJ Teneres
Honda Dax - Previously Owned Bikes: Triumph Tiger Cub, Garelli Tiger Cross, Triumph Trophy 650, Honda CB250 G5, Honda CB750 K7, Yamaha DT175MX, Honda CB250 Super Dream, Yamaha RD350LC YPVS, Honda XR250, Yamaha XT600, Suzuki PE175, Yamaha YZ125, Yamaha RD500 V4, Yamaha XT600 Tenere (3AJ), Kawasaki ZX10, BMW R100GS PD, Honda XR600, Honda Varadero, Honda Africa Twin, Honda Transalp, Triumph Thunderbird, Ducati 900 Superlight FE, Ducati 750 SS, Honda Fireblade, Kawasaki Versys 650, Suzuki GT750 Kettle, Super Tenere
Definitely top end I would say.... camshaft, tappets
- dan3
- What Bike or Bikes Do You Own?: 91 XTZ660 3YF
Triumph Sprint ST - Previously Owned Bikes: CB500X
R1
Fazer 600
DR350
DT125
KMX125 & 200
FZ750 - Location: UK
Thanks for the replies, I managed to download a 3yf service manual.
This auto-decompression system in the camshaft, does anyone have any experience of that failing? The manual doesn't go into much detail...
None of the OEM manuals will go into detail as they were intended for use by trained Yammy tech`s unlike the Clymer manual which is more oriented towards the home mechanic.dan3 wrote: Fri Oct 29, 2021 8:11 pmI managed to download a 3yf service manual.
Search the forum (top right) for decomp or decompression.
Just get TDC, the play at the top lever is 0.5mm. Don’t try to measure it, it’s the minimum movement you can get as free play. Should just feel it with your fingers. The adjustment is simple, halfway down the cable to the kickstart mech. Adjuster and locknut.
Point to note- ensure the cable isn’t pulled anywhere. ( once it’s adjusted and running, give it a tug and feel what happens, it’s acting on the exhaust valve, stopping it from closing fully, making noise and running turns to sheet. Or don’t, and take my word for it).
- dan3
R1
Fazer 600
DR350
DT125
KMX125 & 200
Thanks for the reply donnybach, mine is a 3yf with the centrifugal decompression built into the camshaft.
I'll try to find a NOS camshaft, parts for this bike are common-ish and don't seem to cost too much
Having a bitch of a time with mine. Looks like a new stator may be called for.
I seem to have a love of all things requiring maintenance constantly. If I had a dog it would have 3 legs.
- dan3
R1
Fazer 600
DR350
DT125
KMX125 & 200
charliext1vj
- Halfway there
- What Bike or Bikes Do You Own?: 2 XT600s -1VJ, BSA Bantam Trail, CRF1000, BSA B25 if I can find all the bits!
- Previously Owned Bikes: too many to list - XT600s, cr500, KTM 990 Adv, VFR800, RDs, DTs
Take the tank off and run a small fuel supply as tank will make the sound bounce. Also check the top engine mount - that wont be the issue but if loose they do generate noise. It sounds like more than one noise to me? i.e. there is piston slap as well as valves - assume somewhere in the messages some one said do a compression check too? good luck
