Due to the sorry state I needed a disfunct donor for most suspension parts and electrics. Plus some parts from my bins ...
Most of the plastics were bleached, switches and plugs crumbling.
Me and my son and his girlfriend were working on it for 6 weeks on and off, now the Ténéré is ready to ride for him.
Built it from the naked frame (which I spray painted with 2K PU truck paint).
Had roadworthyness checked Monday, no issues found.
Still some work to be done
- Add pannier/bag rack
- Add some stickers maybe
- Swap stock rear suspension for a Wilbers 640 (slightly shorter) and adjust side stand height
- Mount enduro style mirrors
- Wire heated grips (Daytona) and RAM mounts and 12V sockets for navigation
- Add vents to front fender
- Add oil thermometer
- Mount Acerbis Rallye hand guards
- Give some more TLC to the plastics
- LED rear light cluster
- Swap cable operated choke for a push button one
- Original engine (matching numbers, estimated 70.000 km, needs some love)
- Manual decompression lever
- Original carbie (fitted leaner primary main jet and richer secondary main jet)
- Original exhaust in good nick (after rust removal and repaint, seems to be solid)
- Li-Ion battery on original regulator, so e-start works well.
- 3AJ fuel taps
- Kedo repair sprocket set to prevent further wear on the output shaft
- Ariete fork gaiters
- Stainless steel foot rests
- KTM chain guides
- Braided steel brake line
- Sakura horn
- 3AJ air box with seat oriented intake (cooler)
- Fuel pump delete
- Front disk brake cover delete
- 15-44 (I think)
