I put it down to petrol evaporating out the float bowl & pump, maybe getting an air lock in the process.
You could try tapping the bowl,pump & hoses for a few seconds next time you want to start it after it's been stood a few days or if you have enough petrol in the tank, connect the carb direct to the tap, bypassing the pump, open the tap for a few seconds before you try to start so the bowl has time to fill & see if that has any effect.
The mixture screw problem could be a blocked passageway between the pilot jet & screw in the carb.
You might have compensated for this by setting your throttle slide (tickover screw) high which would bypass the mixture screw circuit but allow the engine to start.
hey guys i am having the same problem i can tell you that my compression is ok as i have 2nd oversize wossner forged piston in it with hi flow inlets and outlets, and dinojet second stage ,crd header pipes and arrow end can
