apk TT600 3AJ00 Rebuild
Anything Electrical
APK
What Bike or Bikes Do You Own?: Yamaha XTZ 750
Previously Owned Bikes: TT 600
KLR 650
Re: apk TT600 3AJ00 Rebuild
Post by APK »
Thanks Mezo
Good news, good starting point.
AP
APK
KLR 650
Post by APK »
Hi
Seems like the TCI unit that I have is the correct one for the bike.
This is the website where i found it, don't know if anybody have tried their products before?
http://www.hpi.be/applist.htm
apk
I can just make out CD4607D on your TCI so that seems the right one, is the wiring loom still TT or do you have one from a 600E (3TB) ?
And i think you would need to replace the reg/rec as well? you can pick up used looms in Germany fairly easy, XT600E Kabelbaum
APK
KLR 650
Post by APK »
Thanks Mezo
Think I'll give wiring the bike myself a go. If any smoke comes out I'll revert to giving the Germans a go.
Might take a while to reach the Southern tip of Africa.
Any advice on where to mount the battery. I think the current holder is too small to handle the larger battery for the newer engine?
AP
If you buy an AGM (absorbent glass matt) battery you can safely lay them on there side, people have done this & mounted them under the seat.
Motobatt are fairly cheap, check the dimensions of there battery’s & the space you have, go for biggest ampage for the e-start.
There could be guys on this forum who have done this already (swapped motors) i forget now? :scratch:
APK
KLR 650
Post by APK »
Will scratch around and see what I can find.
APK
KLR 650
Post by APK »
Wired everything up today to see if we could get a spark and it worked....
Had some help from a good friend.
See if can have it running by the weekend... Hopefully we'll hear some thumping noises.
psahd
What Bike or Bikes Do You Own?: XT 550, TT 600
Post by psahd »
Hi
How is the project going? I intended doing the same thing!
