Danjets Honda Transalp
Danjet600
Re: Danjets Honda Transalp
Post by Danjet600 »
Eric66 wrote:All he told me was that the spoke angles were slightly different (on a XT) don't know more then that, must be slight as he said you only find out when you are nearly finished then you have to start again the right way around.
lucky its a honda then :lol:
Murray Walker
Danjet600
Post by Danjet600 »
i couldn't adjust the hump out of the rims, so i improved my setup a bit, knocked up a adjustable arm to mount the
dial indicator, i was getting 11mm rise where the rim is welded together, so i started again by loosening all the spokes and getting the run out correct first then i will finish off truing side to side :hot:
Murray Walker
And whilst your playing with your wheels Danny ive just had a lovely ruby murray with your missus. :lol:
With added chilli from the garden. :hot:
Danjet600
Post by Danjet600 »
Mézo wrote:And whilst your playing with your wheels Danny ive just had a lovely ruby murray with your missus. :lol:
next weekend i'll get into some more chilli's :hot: :fireball: :kboom:
Murray Walker
Danjet600
Post by Danjet600 »
so i persisted last night and end up with 0.5mm runout with about 3-4mm rise in the weld area on both the front and rear :rtfi:
Murray Walker
So would that be that noticeable then Dan? or would the give in the tire absorb that?
Danjet600
Post by Danjet600 »
Mézo wrote:So would that be that noticeable then Dan? or would the give in the tire absorb that?
i hope it isn't too much :patch:
from my xrv thread
"tolerance for a UK mot is plus or minus 1.5mm generally , with extra allowed at the weld"
Murray Walker
Danjet600
Post by Danjet600 »
well i've done it again :biggrin:
i was looking for good front fairings and found this transalp locally, everything seems to be there the panels and fairings are in good condition, motor has been removed had blown the head gasket from a lack of coolant/corrosion inhibitor, overall condition of switchgear ect is very good - more pics slywink:
seat is spot on
side fairings are in very good shape a crack or 2 but very repairable
no bodgey repairs
motor was running well except for blown head gasket
heads have been done with new valve stem seals and valves relapped
full gasket set and new rings
factory tail light and rear rack
switch gear
spare front guard and bars
so now's where it gets good, i was telling andrew about doing a africa twin/dakar bike color scheme
and he points me to these sitting in his shed :omg:
africa twin tank
headlight and front fairings
head light and dash mount
lights
africa twin seat, rack and aluminum bash plate
well all that lot caught me off guard and i thought fuck it you only live once so i took the lot :funkynanna:
it' now 1am :snore: i'll update mid next week should have enough parts now to get alp no.1
on the road very soon :nordie: :evil:
Murray Walker
Fuck me :omg:
You didn't know he had that AT stuff eh? and you was only just pricing up buying the AT stuff from Europe the other day as well.
The Honda twin gods were smiling on you my son. :nod:
Make a good one to keep & fix up the other & flick it off.
Danjet600
Post by Danjet600 »
Mézo wrote:Fuck me :omg:
i'm thinking TA1 gets the africa twin treatment, it is missing a few bits which can now be replaced with the Africa stuff and it won't be stock standard there will be a few mods here and there to get the EL CHARRO look i'm after
and TA2 is really in good condition i'm thinking build it into a stock trasalp
Murray Walker
