Been shopping around today for one... not much luck
Danjets 3AJ project
Re: Danjets 3AJ project
Where did you get your con rod kit Dan? Was it expensive?
Danjet600
- What Bike or Bikes Do You Own?: xt600e 1991 ex australian army
i bought the motor in peices from mike (monjell82) he had pulled it down and went through it with his trainer "apprenticeship" and he had puchased the rebuild kit so it all came with the motorGeoffD wrote:Where did you get your con rod kit Dan? Was it expensive?
now "mike" can chime in and fill in the blanks
Murray Walker
Murray Walker
- Dirtybrit
- What Bike or Bikes Do You Own?: 1982 XT 550, 1981 YZ250, 2010 Triumph Tiger 1050, 1981 XR 200
- Previously Owned Bikes: Honda SS50, Yamaha RD2501973, Honda XL125, Yamaha DT175, Kawasaki KE175, Yamaha YZ250D, CT90, Suzuki RM400, Yamaha YZ250H, 1981 Yamaha RD250,1982 XT 550, 1979 XS 750, 1979 YZ 400 F.
clutch basket has a bit of wear, wondering should i touch it up with the file to get rid of the ridges
I would file those little grooves smooth if i where you Dan,that can only cause you problems.
Its great reading these builds again.
Danjet600
got stuck into the head, first problem was this
sprayed wd40 penetrate on it everyday for a week, hit it with heat no go
so i butchered it with the die grinder tried to thin the walls and punch it inwards still held firm
right time for plan B welded a bolt into the shredded remains and made a puller
got ya
pulled the valves for inspection
inlet look ok
exhaust are a bit ruff
got ya
inlet look ok
Murray Walker
Murray Walker
That amount of wear is of no consequence. At most give it a little touch-up with emmery paper to smooth it up.clutch basket has a bit of wear, wondering should i touch it up with the file to get rid of the ridges
Danjet600
barrel bored out for the tenere
and i lashed out on a wiseco piston
Murray Walker
Murray Walker
Danjet600
had a play around with some photo's, stole mez's motor and geoff's wheels
Murray Walker
Murray Walker
Yep you can see the grass is defiantly greener in Geoff`s garden.
M.
M.
Danjet600
maybe without the wheels
Murray Walker
Murray Walker
MEZO wrote:Yep you can see the grass is defiantly greener in Geoff`s garden.![]()
M.
Yeah, 'cos we get so much poxy, bloody rain......
