Diagnosing a lovely knocking noise
Re: Diagnosing a lovely knocking noise
Nice one. 👍
So you did not find any loose parts or wear, and apart from gaskets the only thing you changed was the camshaft including decompression mechanism?
Piston etc still the same?
dan3
What Bike or Bikes Do You Own?: 91 XTZ660 3YF
Triumph Sprint ST
Previously Owned Bikes: CB500X
R1
Fazer 600
DR350
DT125
KMX125 & 200
FZ750
Post by dan3 »
motorang wrote: Tue Nov 16, 2021 9:13 am So you did not find any loose parts or wear, and apart from gaskets the only thing you changed was the camshaft including decompression mechanism?
I didn't change the camshaft in the end as they all disappeared from the Internet once I started looking for one. I only changed the gaskets and set the valve clearances.
Maybe the timing was out ever so slightly? Is that possible?
Did not sound like it, really. No loose engine frame bolt?
dan3 wrote: Tue Nov 16, 2021 1:01 pm
On a number of different xt’s I have accidentally made the valve clearances be way way off when resetting them. I would rotate the engine to tdc, set the clearance, and then rotate the engine a few times only to find that my clearances were off by a mile. Somehow the original tdc wasn’t properly setting the rockers or the valves or something got off and i had to do the valves a second time to make sure the clearances were right. If not double checked before closing up the engine and running it, that gap between the rockers and valves would make the kind of knock in your video. Obviously too late to know now if that was the case since everything got taken apart and put back together but that has been my experience in the past.
Glad it’s all running smoothly for you!
It definitely sounds like the valve to me. I’d be interested to know if that newer decompression system you had can stick open too. Just glad your sorted. Lovely motors when they’re on.
Just need a good synthetic fuel supply in the future to keep em going.
Surely the energy in space dust sherbet in the ‘70s could be harnessed? :stir:
dan3
Triumph Sprint ST
R1
Fazer 600
DR350
DT125
KMX125 & 200
FZ750
Post by dan3 »
motorang wrote: Tue Nov 16, 2021 2:36 pm Did not sound like it, really. No loose engine frame bolt?
Nope
dan3
Triumph Sprint ST
R1
Fazer 600
DR350
DT125
KMX125 & 200
FZ750
Post by dan3 »
scottieh wrote: Tue Nov 16, 2021 5:36 pm
Cheers scottieh, I'll bear that in mind if it happens again.
dan3
Triumph Sprint ST
R1
Fazer 600
DR350
DT125
KMX125 & 200
FZ750
Post by dan3 »
donnybach wrote: Tue Nov 16, 2021 6:31 pm It definitely sounds like the valve to me. I’d be interested to know if that newer decompression system you had can stick open too. Just glad your sorted. Lovely motors when they’re on.
I'll be drilling for my own oil if need be! Not ready to go electric yet
