Those wheels.....so sexy
Are you going to paint that engine in black?
Nice CX 500 proyect.
This was my first bike,I was 17
Re-sleeving is cheap and easy to do. I have just done one for Xpag. You can buy a sleeve on ebay for $80. Heat the barrel in the oven or with a big propane gas torch and press out old sleeve. Only 3 or 4 tons pressure required, which is tiny in press land. I am away in pommyland at the moment, but intend to post pics of the re-sleeve operation we did the week before I left.I'm considering the cost of pressing out the old sleeve and pressing in a new sleeve as compared to finding a new barrel with fairly new sleeve in it. Any help with this would be appreciated.
Safely arrived and was walking down the Strand and Pall Mall this very afternoon. Also took a ride on the London Eye.....not recommended for vertigo sufferers!Dave`s arse in 40,000ft in the air right now on his way to Pomgolia for his European tour
Most rebore increments are 0.020" (20 thou) or 0.5 mm and are generally available up to 4th oversize (2.0mm or 80thou).Can you confirm this? I'm concerned because I'm not sure how much more I can bore out the cylinder and still get a piston and rings for it. Does Yamaha make a 2.5 overbore or how about Wiseco? Right now it's the only thing I am really concerned about. I'm considering the cost of pressing out the old sleeve and pressing in a new sleeve as compared to finding a new barrel with fairly new sleeve in it. Any help with this would be appreciated.
Also, Actionman, I'm trying to interpret your case splitting explanation. How much of the engine needs to be taken out of the case before I can insert the mate 1.25mm rod into the lefthand case side and begin screwing. Also, what exactly does the rod push against? I'm about ready to take the flywheel off and I'm not sure if I should yet. Thanks everybody, this has been fun so far.
. Now it won't accept a thread and it needs to be tapped to get some bite back into it. I can't understand how this flywheel is in the engine so tight. Joel can't understand it either. There are no bolts holding it on anymore so it's just in there and just needs to be turned out, right? We even took out the three bolts holding the starter clutch onto the flywheel out so it's not being pulled out along with the flywheel. Am I making a mistake?
