mjoneill82
- What Bike or Bikes Do You Own?: XT600`s
wow, i mean wow, you cleaned those brakes up, they look like they could pass for new ones.. im watching and loves it
mjoneill82 wrote:wow, i mean wow, you cleaned those brakes up, they look like they could pass for new ones.. im watching and loves it![]()
Fred333 wrote:Hello Geoff,
This is awesome!!!! Very good work! I had thrown away these brakecalipers. But you take your time... and then like new!
Great!
I want to put a doupledisk onto my TT 600 aswell. Got all the parts laying arround here.
I look forward to your report on how is braking then...
You get this:
and this:
and this![]()
from me
Fred
Thanks guys....
Tenere 3....
Chromed swinging arm....
So this bike is fitted with the 3TB engine, which I've started another thread detailing the strip down.... the previous owner had the bike for 7 or 8 months & couldn't get it started, he bought 2 new ign switches 3AJ & 3TB & also 2 wiring harnesses... loads of other bits with it too... he just got fed up with it... I must admit its a bit of a heap... I've stripped it down but won't be starting on this one till the other two are finished....
Forgot to mention.... on Tenere 2 the exhaust had been blowing for some time & the hot gases had melted a hole in the side panel & right through the seat...... the guy had fitted a new tail pipe before I got it, I sold that on ebay...
Just won a bottom end & head on Ebay......
Can't post any pics till photobucket have sorted themselves out
But here's what he said about it
hi,,this is a slip stream tuned yamaha srx 600 engine bottom end,,this was built by martin sweet,,
Ok,,
CARILLIO ROD,
BALANCED CRANK.
ALL NEW BEARINGS THOUGH OUT,
has not done that much work,,its only had about 40 hours of use,,i will be keeping the clutch basket and the flywheel..
This is a very strong bottom end and would make a good base for a 101mm top end,, i ran it with a 98.5 piston and a bob farmham head,,and it was quick
and the bottom end was never under any stress,,
hi,,this is a head for a srx 600 prefix 1JK.
it was flowed ported and had the valves recut to 3 angels. this removes any valve gas dwell time,,so its a bit like have a bigger cam shaft but with out the tick over or heat problems,
Its two matching parts and the bearing faces for the cam shaft are sweet,, very low use..may be less than 40 hours,,
Match this to a big bore set of header pipes and a good set of carbs and a over bored cyclinder and you have a single to rock with,,
Ok,,
CARILLIO ROD,
BALANCED CRANK.
Nice work Geoff.
Did you use a snipe service?
ActionManMelb wrote:Nice work Geoff.![]()
No I just waited till the last 30 seconds & banged a bid in.....
- Dirtybrit
- What Bike or Bikes Do You Own?: 1982 XT 550, 1981 YZ250, 2010 Triumph Tiger 1050, 1981 XR 200
- Previously Owned Bikes: Honda SS50, Yamaha RD2501973, Honda XL125, Yamaha DT175, Kawasaki KE175, Yamaha YZ250D, CT90, Suzuki RM400, Yamaha YZ250H, 1981 Yamaha RD250,1982 XT 550, 1979 XS 750, 1979 YZ 400 F.
Sound's good Geoff!
Dirtybrit wrote:Sound's good Geoff!
Hope so.... should be, Martin Sweet is the engine builder for the MZ racing team. they use XT engines so he should know what he's doing .....
I've been waiting three weeks for fork gaiters/boots for Tenere 2... I got some off ebay but they were shit.... so I ordered some off that Maico guy in New York.... (remember him Mezo) ... anyway had a card in my postbox yesterday the postman didnt deliver em cos he couldn't get them in the letter box... so I had to go pick em up at the sorting office, 20 miles away.... so off I went tonight ... & guess what... yeah they've fucking lost 'em....aaaarrrrgggghhhhh bastids..
Good one Geoff, lucky i never saw it & stuck it on the "spotted on ebay" thread.
That guy with the gators, is that rampidcat your talking about?
The crap gaiters came from a seller called p-k-n.... the good seller is rpmmagicat, you sent me a link to him last year.....
