Page 8 of 8
Re: Bernieboy's 34l Resto
Posted: Thu Apr 11, 2013 9:41 pm
Got a link for your nose camera Bernie? was it an ebay jobbie? how much etc? i need one.
Posted: Sun Aug 25, 2013 1:09 pm
by Bernieboy
Well, got it registered this week (club reg of course) and took it for a shake down ride today. About 150k's east of Melb. Had a few problems with fuel starving, maybe intermittent blockage somewhere.? The oil burning however was pretty bad. You may recall when I did the motor I honed bore and replaced rings. After I had done about 100k the blue smoke subsided and thought it had bedded in a little, however when I stopped at some lights I heard a bit of a "pre seizure" squeal from below. Pulled over and checked the oil (none visible on the stick!!) some fumes emmiting from the oil tank. :omg: Approx 1lt per 100km! So I put a litre of oil in and rode home (blue smoke had returned) Seems like I will need to a rebore aferall. I have a piston kit so it will be my next job. :biggrin:
Posted: Sun Aug 25, 2013 9:35 pm
And for those who never saw it before Bernie restored it, here are some pics.
Another classic saved. :biggrin:
Posted: Mon Aug 26, 2013 4:58 am
Was the bore ever measured to see if it wasn't worn too big before even honing? Sometimes it works to get +.01" (commonly called service rings) and just gap them for the bore and run in the worn std bore as long as there is no piston slap going on.
Posted: Mon Aug 26, 2013 12:36 pm
by Bernieboy
Yes, put in oversize rings and filed them down to get the gap correct. Doesn't appear to have worked on this occasion. :oilleak:
Posted: Mon Aug 26, 2013 3:14 pm
That's actually odd then that they didn't seal yet no slapping, usually it works at least for a good number of miles, those that didn't the bore was so big that the skirts would break from tipping. Are you sure a valve seal isn't leaking or, errr, ummmm, ,, .................................................... not istalled? :storm:
Posted: Tue Aug 27, 2013 7:51 am
by Eric66
Looks great Burnie :congrats: Did ya put any air in the forks,they look a bit saggy (12psi with a bicycle pump)gives them a lift.Ya better give Actionman a prod so he starts restoring some of his herd :lol:
Posted: Thu Aug 29, 2013 2:55 am
by xpag6259
Well done BernieBoy. I used to have one that looked about that good!
paul
