Chain Rollers
Brer
What Bike or Bikes Do You Own?: 1988 XT 600Z Tenere
Previously Owned Bikes: Puch Maxi
Sim 50 grass track bike
Yamaha TY 80 Trials bike
Yamaha DT 50
Honda CB 175
Maico 400
Ducati 750ss
Chain Rollers
Post by Brer »
Hello all
I have a question to ask, it might sound stupid but bear with me
I need a new swing arm guard and new chain rollers top and bottom on my 3AJ 1988.
Question is
Do I need model specific parts or will any XT parts fit.
Thanks in advance
Brer
Re: Chain Rollers
Post by xtrider »
As far as I know they're all the same. Rollers from many other models and even other brands of bikes and quads work also, they just have to have an 8mm x 1.25mm bolt.
Brer
Yamaha DT 50
Honda CB 175
Maico 400
Ducati 750ss
Re: Chain Rollers
Post by Brer »
Thanks for that XT
I didn't want to shorten the chain before I had the info, just in case.
Cheers,
Brer :headslap:
Matt-Tenere
What Bike or Bikes Do You Own?: Yamaha Tenere 600 3AJ '89, Cagiva Elefant 900ie x2,E900,Beta 300 RR ,Yamaha Tenere 1VJ, Husqvarna CR 250 '76 twinshock
Previously Owned Bikes: Various motocross bikes ranging from 1975-2003,all the Jap brands.Enduro bikes also,Husaberg 450,Husqvarna 360, Italian TM's were a favourite.Road/trail bikes including 3 Yam Tenere 600 over the years,MTX 200,Aprillia RX 125,DRZ 400,DR 350s...
Re: Chain Rollers
Post by Matt-Tenere »
Hmmmm,my 3AJ has a fixed metal boss to the frame for the upper chain roller.A thin plastic sleeve fits over that and then the chain roller.The actual roller has no bearings and has an inner diameter of 17mm approx. Without removing the metal boss fixed to the frame,I can't see a standard off road roller fitting.Both my outer plastic rollers were missing and I got a set of universal chain rollers from MD racing in England.These are plain without bearings but I had to open up the centre hole to fit over the standard thin plastic sleeve.
I had a !VJ lying about and it had the same fixed metal bosses on the frame as my 3AJ.
Re: Chain Rollers
Post by xtrider »
Our all just have a 8mm threaded hole in the frame(maybe a welded nut on the frame IIRC now), that's it . then a roller with an 8mm bolt screwed into it, top and bottom.
[/.color]
