What's this wire on battery?
Posted: Sat Feb 27, 2016 6:24 pm
Afraid I'm going to be a bit vague here, just hope someone can offer guidance!
Just putting things back on the bike; 1VJ
There is a connector to the positive and one to the negative terminal. Negative is spliced into the main negative lead; looks very genuine.
But... the lead going to the positive terminal.... first it is black... then it goes to a chocalate block with two blacks coming out!....
Vague like I said....
Okay, if I connect an ohmmeter to that lead going to the positive terminal, I get approx 78 ohm to any earth point.
Before I rebuild the carbs and start it etc. any ideas what this might be, or how to check what it might be?
John
John
