Chain rollers
rhobgoblins
What Bike or Bikes Do You Own?: XT 600 Tenere 1vy
BMW R1100GS
Honda CB500X
Previously Owned Bikes: K100
XJ750
R1100S
CX500
Chain rollers
Post by rhobgoblins »
Hi, could I ask some advice about chain rollers? I've recently acquired an '87 tenere which I intend to give a cosmetic uplift - mechanically it's sound. My question is with regard to the chain rollers I ordered some replacements for lower and upper which when they came were both exactly the same. When I went to fit them, the top roller had long gone but there was a tube welded to the inside of the frame where the roller goes and which stops the new roller from being fitted - it looks like it's meant to be there. Is there a different type of roller? Also, what does the top roller do? It looks too high up for the chain to be routed over the top of it. Any help would be appreciated.
Many thanks
Rob
Re: Chain rollers
The rollers on the Tenere are different top to bottom, if you go to the Kedo website and search for roller (under xt600z) its the 4 Piece one, bolt, washer, tube (which fits over the one you mentioned on the frame) and the roller which fits over that.
just found this example on e bay item number 170876936508
rhobgoblins
BMW R1100GS
Honda CB500X
XJ750
R1100S
CX500
Re: Chain rollers
Many thanks. Is the chain supposed to run over the top of this then - it seems like it's positioned too high?
Re: Chain rollers
Post by Eric66 »
No, the top roller is there to limit the amount the chain can rise during suspension movement.
rhobgoblins
BMW R1100GS
Honda CB500X
XJ750
R1100S
CX500
Re: Chain rollers
Cheers.
Bike just needs a bit of a spruce up and should look very good when done. It's an Italian import and I guess benefited from a kinder climate. I'll try to post some pictures when done.
rhobgoblins
BMW R1100GS
Honda CB500X
XJ750
R1100S
CX500
Re: Chain rollers
Re: Chain rollers
That does look quite tidy, well done :tenere:
