For sale: front brake calipers and rear mudguard
Posted: Sat Jul 29, 2017 2:33 pm
Hello,
Brand new forum member, but I've been reading for a while. Living in the UK, Kent.
I have items left over from fixing up my bike if anyone is interested?
I am willing to post if you would cover the cost.
Tenere front brake caliper (no idea from which model), in very good condition. (Stripped and cleaned.)
The bore and piston have some tarnishing, but it's minor. The guide pin on which the caliper halves slide is like new. Brake pads included.
Distance centre to centre of mounting bolts is 106mm.
Weighs 1050g packaged up £40.00?
Tenere front brake caliper (no idea from which model), in less good condition. (Stripped and cleaned.)
The piston and the bore both have tarnishing, but are not pitted as far as I can see. The guide pin on which the caliper halves slide, has corrosion.
Weighs 865g packaged up £20.00?
Rear mudguard, and tail light.
When I bought it, was described as from a 1VJ Tenere, and 'uncut'. I decided I couldn't use it. I think it is uncut, though it has the usual scrapes and scuffs.
Weighs 1220g packaged up £20.00?
I have photos of them all... but no idea how to put them on this forum. But I'd be happy to provide one way or the other...
Cheers, SteveT
Cheers, SteveT
