Page 1 of 2
Clutch slipping??
Posted: Mon Mar 01, 2021 12:24 pm
by Lozza
Hey fellow Tenere members - seeking some guidance/advice.
I did a 600km ride over Sat/Sun and noticed the back wheel slipping when going up hills - dirt, tarmac. I initially thought the tube was slipping but not the case. My second thought was clutch?
Any thoughts or advice before I crack the case and start investigating?
Cheers, Laurie
Re: Clutch slipping??
Posted: Mon Mar 01, 2021 2:39 pm
by Hawk
Easy way to check if clutch is slipping .... high gear, low speed and then WOT.
Could the tyre be slipping on the rim?
Posted: Tue Mar 02, 2021 8:52 am
by Lozza
Hmm, WOT? Not sure what that means?
Definitely not tyre slip as no damage to the tyre in anyway.
Posted: Tue Mar 02, 2021 11:29 am
by Hawk
WOT = wide open throttle.
Low revs, high gear and then twist the grip all the way round (WOT).
revs will rise without forward shove if clutch is on way out
Posted: Thu Mar 04, 2021 8:30 am
by Lozza
Thanks Hawk - will give it a go on the weekend.
Posted: Thu Mar 04, 2021 9:56 am
Lozza wrote: Thu Mar 04, 2021 8:30 am Thanks Hawk - will give it a go on the weekend.
Use one of the 'WHITE" permanent markers (if you have one) on your rim & tyre to see if its slipping on the rim.
If that is not worth the expense just make a mark on the rim (or a bit of electrical tape) near a letter on the tyre or something you would remember, just to see if its slipping on the rim.
EDIT: What oil are you using? semi synthetic i would hope?
Posted: Thu Mar 04, 2021 1:26 pm
Before you do anything, make sure there's free play on your clutch cable (is your clutch lever tight, or is there some free play?)
Posted: Sun Mar 14, 2021 2:10 am
by Lozza
So have tried a few of the recommendations this weekend.
1. Low revs, high gear and then twist the grip all the way round (WOT).
- I put the bike in 3rd gear, cracked the throttle - bike lurched forward and revs also increased
2. Check the tyre on the rim and no movement at all
3. I use Castrol Power 1 10w-40 Part Synthetic Oil - should I be using something different?
4. I have also noticed that the 'play' in the clutch cable isnt much so have adjusted.
Posted: Sun Mar 14, 2021 7:45 am
Lozza wrote: Sun Mar 14, 2021 2:10 amI use Castrol Power 1 10w-40 Part Synthetic Oil - should I be using something different?
Well most people will say use semi synthetic on these bikes, if those plates have had mineral oil on them they will be contaminated (cannot be cleaned).
I would suggest buying a new clutch plates & use semi synth in future (don`t forget a new filter).
Posted: Mon Mar 15, 2021 10:22 am
Mezo wrote: Sun Mar 14, 2021 7:45 am
Part synthetic & semi synthetic are the same thing, Castrol power 1 is good stuff :thumb:
