1VJ carb on 2001 motor
Posted: Fri Nov 05, 2021 12:43 pm
by Spike
CARBY EXPERTS
I have the above arrangement on my 1VJ can anyone see an issue with this?
I have an issue that may or may not be related, that being after about 5klm of riding the old girl seems to be fuel starved and stops, hit the starter after about 30 seconds and all seems well and ok. Is it possibly a float issue? or something else....
Re: 1VJ carb on 2001 motor
Posted: Fri Nov 05, 2021 10:08 pm
Firstly Nick, and i always say this as it caught me out & many others. :rtfi:
Is the float needle valve filter clean?
Mezo. (Banana Bender)
Posted: Sat Nov 06, 2021 12:46 am
by Spike
Yes, it should be as l had the carb rebuild by a proper motorcycle mechanic, but l will take the bowl off and check all is ok inside there
Posted: Sat Nov 06, 2021 10:02 pm
Spike wrote: Sat Nov 06, 2021 12:46 am Yes, it should be as l had the carb rebuild by a proper motorcycle mechanic, but l will take the bowl off and check all is ok inside there
And in our line of work what's them magic words? never assume. :rtfi:
Download the CARB TUTORIAL Nick, page 16 onwards is where you need to be checking.
Posted: Mon Nov 15, 2021 11:57 am
by Spike
Is it possible that there is a vacuum forming in the petrol tank?
Posted: Tue Nov 16, 2021 9:16 am
by motorang
To complete the trinity of fuel restrictions, the stuff between fuel tank (Breather in cap) and carb should be taken into account. Clogged taps, fuel lines, or fuel suction pump if there is one on that bike.
