XT660x running battery flat
Posted: Tue Jun 14, 2022 3:43 pm
by Alwyn
Any advice would be appreciated please:
Issue as follows. had a couple of times now where the engine management light comes on and within a minute or so the motor cuts out. The battery at that point is flat. So when, after charging the battery, I run tests everything seems fine. The 3 white wires at the rectifier reads 24.2 Volts. The red wire to battery neg terminal reads 5.5V. With rectifier back in line, the battery terminals read 12.6 V (engine off), with engine on it reads 14.2V.
So, I'm wondering if one of the coils could fail when the motor is hot? someone with experience of this issue?
Re: XT660x running battery flat
Posted: Wed Jun 15, 2022 1:33 am
by motorang
Hi
not knowing the bike some of this does not make sense to me:
Red wire to battery negative terminal??
If this is a standard three-phase voltage regulator/rectifier (3 white AC wires in 1 red DC wire out) this is the positive terminal to be connected with. Regulator needs ground as well, so usually there is a grounding cable from one regulator fastener to battery negative terminal (or black harness wire).
You could fit a 12V socket to the bike and plug in a voltmeter plug, so you can check what the voltage does while you ride. Ignition will cut out well below 11 volt usually.
Could be as simple as a bad battery.
Posted: Wed Jun 15, 2022 8:11 am
by Alwyn
Thanx Andy
Yes, pretty standard
I would have thought that the voltmeter across that red terminal to battery neg would read around 12+ V. the 5.5V seems anomalous to me but auto electrics is not my strong point
Thing is I replaced battery just before last winter, so I was thinking it is unlikely but you may well be right and I should not ignore the obvious. I'll load test the battery
