FRONT FORK 'OIL LOCK PIECE' / 3GM231730000 Spindle, Taper
Posted: Wed Apr 10, 2024 1:04 pm
by TTXTZ3YF
Hello
I have a 1996 XTZ660 4MY3. Dismantled front forks to fit new oil seals and found I have no "FRONT FORK 'OIL LOCK PIECE' / 3GM231730000 Spindle, Taper" fitted !! Can anyone say if this is important? Forks basically worked ok without. Is it perhaps just to make it easier to locate bolt into damper rod on assembly or is it more than that? They appear to cost £40 each, if I can get them. Any advice would be gratefully received,
cheers
Tony
Re: FRONT FORK 'OIL LOCK PIECE' / 3GM231730000 Spindle, Taper
Posted: Thu Apr 11, 2024 6:25 pm
by charliext1vj
Tryingvto work out what it is on this phone...isn't it the dust shield? As long as fork seal has the locking ring should be ok...but will wear quicker....will try and look on lap top later!
Posted: Thu Apr 11, 2024 8:03 pm
by TTXTZ3YF
Thanks for the reply. It's not the dust seal. It's inside the fork at the bottom of the damper rod - no 10 / 27 in this diagram.
cheers
Tony
Posted: Thu Apr 11, 2024 9:13 pm
by charliext1vj
Yes looked at - looks critical part and needed - but I guess you know that. As you say £40 for it compared with a set of second hand forks for circa £100. Had a quick look round nothing jumping out cheaper - good luck
Charlie
Posted: Fri Apr 12, 2024 10:15 pm
by TTXTZ3YF
Thanks for the reply Charlie, much appreciated.
Posted: Mon Apr 15, 2024 4:48 pm
by XT3DS
The oil lock piece acts as a hydraulic bump stop for the last millimeters of travel of the fork. You could assemble your forks without it if you don't plan on ever bottoming out your suspension, but such situations are not always planned. It's better to find another one and install it.
Posted: Mon Apr 15, 2024 9:30 pm
by TTXTZ3YF
Thanks xt3ds. That makes sense, I'll see if I can get them ...
Posted: Mon Nov 18, 2024 2:52 pm
by novavoyager
Thanks for the information.
