34K03 Cilinder on 1VJ - headgasket
Posted: Tue Feb 04, 2025 12:13 am
by Duc_Rider_NL
Good day,
Does anybody know if a 34K03 cilinder fits a 1VJ?
As I know this cilinder has the upgrade threads and the issue of head gasket failure is gone. Is that right?
Cheers Nick
Re: 34K03 Cilinder on 1VJ - headgasket
Posted: Tue Feb 04, 2025 8:16 am
by donnybach
Should fit, shouldn’t it? I thought they only changed for the 3aj. But I’m not a spotter. Have you tried it? It will match or it won’t.
Posted: Tue Feb 04, 2025 6:15 pm
by Duc_Rider_NL
Yeah, I’d like to have it verified before I buy it.
Nick
Posted: Wed May 07, 2025 8:56 am
by blackshark
yes it will fit, I've read that they were fitted standard to the late 1VJ, so some time in 1987, I have an early 1VJ that has a 34K03 cylinder fitted by a previous owner.
Posted: Thu May 08, 2025 8:13 pm
by cadno
I'd be a bit careful here.
The cylinder/barrel will fit on the cases. But it will depend on what cylinder head you have.
Photo proof below.
1VJ cylinder head.
Stud gap around 134mm.
Later 3AJ type barrel.
Equivalent stud gap 145mm.
So a check of your cylinder head stud gap would be advisable.
