Acerbis plastic tank decal
Posted: Sat Aug 09, 2025 4:50 pm
by drumnagorrach
Can anyone recommend a tank decal for the acerbis 23 litre plastic tank ? It hasn’t got a smooth surface so I wonder if anyone has managed to get a Yamaha decal to stick to and stay stuck to it .
Re: Acerbis plastic tank decal
Posted: Sat Aug 09, 2025 9:09 pm
by Missinglink
What like this....
Posted: Sat Aug 09, 2025 11:46 pm
by drumnagorrach
Well just a simple Yamaha would do . Is that an acerbis plastic tank ?
Posted: Sun Aug 10, 2025 8:53 pm
by Missinglink
Yes fella....
Posted: Mon Aug 11, 2025 9:24 am
by drumnagorrach
Fine , what sort of decals did you buy ? This is like pulling teeth
Posted: Mon Aug 11, 2025 11:46 am
by Missinglink
It's nothing special, just a standard graphic, the surface of your tank sounds suspect.... if it's rough or pourous then you'll be on to a hiding to nothing.
Posted: Sat Aug 16, 2025 6:59 pm
by drumnagorrach
My tank is new , and I wonder if there is a mould release agent on the tank . I tried a couple of vinyl decals and they didn’t stick .I cleaned the area of the tank with cellulose thinners prior to attempting to stick the decals to no avail .
Anyone fitted vinyl decals to an Acerbis plastic tank ?
Posted: Sat Aug 16, 2025 9:51 pm
by scottieh
Some plastics don’t like adhesives very much. Clarke brand motorcycle tanks in the USA are made of a roto molded plastic that will not chemically bond to adhesives, glues, or paints so stickers just fall right off, paint peels, and plastic and epoxy repair patch kits for damages are useless.
I don’t know what the formula for Acerbis plastic tanks is but it might be using a similar plastic.
Posted: Sun Aug 17, 2025 7:46 am
by Scumfrog
I didn't have any problems. However this tank has had a lot of work to get it to this condition, I.e. scraping and sanding.
Could cellulose leave a residue on plastic? I use isopropyl alcohol.
