I have modified the airbox and changed to the under seat inlet, new oil pump is next on the list as well, but I was keen on keeping an eye on things like temperature sooner rather than later.
Fitting the Trail Tec is very simple, just some thermal paste (that was supplied) into the radiator slot, then insert the temperature probe.
then a few zip ties up to the phone mount.
From eBay
https://ebay.us/m/geqsC5
Gives a good idea of how the bike is warming up and the radiator temp, this is obviously affected by air flow, so not a true reading of oil temp, oil temp at the tank is approximately ten degrees higher when moving but they equal out when the bike is stopped.
Oil tank temperature is monitored by an analogue oil filled filler cap gauge from KEDO.
https://www.kedo.com/catalogsearch/resu ... 69+Special
Still quite cool in the UK at the moment, but off round Scotland in the summer so this adds a little piece of mind.
