POWER
Posted: Tue Oct 02, 2012 1:51 am
1600 asked me this on another thread, thought it better to start a new thread
"Any thoughts Rick, suggestions, whateva, on better carbs?
Has anyone fitted something differenet than the "so-so must" of Raptor atv BSR33 carbs? (or BST...cant remember now...)
For example, what about a donation from the latest TTR600 (1998-...conventional forks), that uses 2x30mm Teikei, instead of the classic 27mm of the almost entire XT range?
Should there be a benefit?...wondering..."
1600, 1st off I'm assuming you want to change carbs for more power, hence the title of the thread.
If the carbs are the biggest restriction then bigger carbs will give you more power, providing you can jet them properly.
If the air box, filter, manifold rubbers, exhaust, head etc. are a bigger restriction then bigger carbs won't have much effect.
The BSR33s are CV carbs which don't flow as well as conventional slide carbs, the 33mm bores probably flow the same as 27-28mm slides.
Have you heard they are better?
Are you sure about the 30mm TTR600 bore sizes?
The CV side of my 660 has a 35mm bore
The problem I have with teikei carbs is lack of info on needles & needle jets, you can get different size pilot & left carb main jets but I've never been able to find out teikeis' formula for needle tapper. Don't know what 600s are like but my 660 is quite sensitive to needle clip posission making it hard to get descent fuelling, knowing different needle tappers would make it easier (with the help of a lambda meter
34mm smooth bore/flat slide mikunis & keihiens are popular with MZ & SZR660 riders but they're not cheap.
When I had more cash I wanted a SZR to tune for track days & hooning about, thought about fuel injection, even whittled a lump of alley to take flat slides I was going to use as throttle bodies.
Running out of money might have been a good thing, saving me a lot of head ache.
