Bit of a confusing issue here.
Baught a new set of OEM rings for my 43F XT600.
Typical 2 rings + oil control set up.
Manuals state that stampings go up. No problem there.
OEM manual says: both rings (non oil control) are square.
Clymer says:
Middle ring is square. Top ring is slightly tapered at the outer surface (doesn't state if the taper is at the top or bottom)????????
Here is what I have:
2 rings with markings stamped. . On one the edge (to cyl wall) is crome colour. Other ring has charcoal grey colour. Crome one looks square, Charcoal one looks a bit tapered wide at bottom to narrower at top if oriented with stamped marking up.
The above info doesn't add up???????
My mechanic and others say:
Put the crome one on top and the grey one in the middle. This doesn't compute with the OEM's info as they are not both square????
I'm not sure if this works as Clymer suggest's because they are so vague in the description of "taper". Should it taper top to botttom or bottom to top?????
Second issue:
Oil control rings have no marking/stampings. Can they go either way? Do they have a taper/shape I need to orient? They are 2 thin rings with a waffle shaped bit in the middle.
Please help one very confused home mechanic. I have searched the web, it's all over the map on what to do
Many thanks,
Pawlie
