Eric66 34L Resto
Re: Eric66 34L Resto
Eric66 wrote:Got the day off tomorrow so will hopefully finish the paint job on the tank etc.
Then just park that one in the living room Eric. :nod:
Post by Eric66 »
Shit NO!!! That's like keeping a bird in a cage. The "New Girl" will be used and abused :shades:
itchywheels
What Bike or Bikes Do You Own?: !989 XT600Z TENERE. Honda ZOOMER 110. Triumph Tiger 800.
Previously Owned Bikes: Loads
Post by itchywheels »
Eric66 wrote:Shit NO!!! That's like keeping a bird in a cage. The "New Girl" will be used and abused :shades:
:rofl: That is o so true.
"For my part, I travel not to go anywhere, but to go. I travel for travel's sake. the great affair is to move."
(Robert Louis Stevenson)
Post by Eric66 »
Got the tank and headlight cowl base coated,next step is to give it a light rub with a scotch-brite ,apply the stickers and then clear coat.
Also fitted the chain and I used my new chain breaker from Terra-X, works bloody brilliant.I got the tyre levers and the spanner set as well, the levers have different size nut holes which you use to hold the chain breaker or undo nuts,the spanner set also slips on the end so you can undo your axles etc.
Had some trouble with the side covers, even using the plastic primer so now have applied an isolation coat which seems to have fixed the problem. Put my other tank on and had a fang around the yard,goes real nice.
You Scotch the whole tank Eric? not just where the graphics are going.
Fred333
What Bike or Bikes Do You Own?: Yamaha TT 600 1984
Previously Owned Bikes: Vespa Rally 200, Vespa SS 50 and alot more old (real) Vespas!!!
and.....?
Post by Fred333 »
Hi Eric,
nice tools!!!
I looked at their shop.
200 Aussidollars just for tirelevers and a chainbreaker!
But ... nice tools....
Cheers Olli
PS: Did you get those for less? Where?
Yamaha TT 600 36A59X3SW - Mix
Post by Eric66 »
Mezo first, with base coat you normally apply the clear 30 mins after the base as the base still needs to be soft for the clear to bite. This does not allow enough time to place the stickers so I let it harden then lightly rub it with the scotch brite,(the clear needs a slightly rough surface) place stickers then clear coat. Oli, I paid full price for these tools as they are the best you can get and will last a life time :shades: And Aussie made :nahnah:
Eric66 wrote: And Aussie made :nahnah:
So, made in China then, :chinese:
bosley1980
Trusted
Trusted
What Bike or Bikes Do You Own?: YAMAHA XT600E (1998)
YAMAHA TENERE 700 (2019)
HONDA CB1100RS (2020)
Previously Owned Bikes: BMW R1200GS (2006)
HONDA CRF250RALLY (2017)
YAMAHA XT660Z Tenere (2013)
HONDA CRF250L (2015)
MZ150ETZ (1988)
Post by bosley1980 »
Eric66 wrote:Hi Bosely, the pegs are great and make a amazing amount of difference when riding through rough and hilly trails as I can move my feet and change where the weight is placed :ride: I'll be ordering another set for the "New Girl" soon.
HI ERIC,
I have now Mark VII in Stock and Mark V too. Or you're not with rebuilds so far?
Thinking of you, remember.
Post by Eric66 »
Gave the painted bits a light rub with a scotch brite and applied the stickers and then gave it all a clear coat. The black stickers for the side covers were too big so I did not use them, I will spray the black sections with satin later as I did not know if the acrylic satin would react under the clear but pretty sure that you can spray acrylic over the clear if you understand.
The red blocks on the stickers are on a white back ground, I separated the first 2 that I put on by cutting the white out but left the rest as the white paint I used (RAL 9016) matched perfectly and they were easier to apply in one piece.
The clear coat went on perfect this time, a couple of days hardening and she is finished :guinness: :guinness: The last pictures look like there bubbles or something under the red but it is just the way the picture came out.
