Tank / Fairing fixings
uglybassplayer
What Bike or Bikes Do You Own?: Nothing currently! Looking for a 660 Tenere
Previously Owned Bikes: Yamaha XTZ 750 Super Tenere
Yamaha XJ 600 (Pre Diversion)
Post by uglybassplayer »
I've managed to strip the threads in one of the captive nuts fixing the fairing to the tank on my 3AJ, i suspect the aftermarket/stainless bolts fitting by the previous owner (which look great) are harder than the original bolts and the steel of the tank and a few tank removals and fittings has finally worn/pulled the threads. I also suspect the other three bolts aren't far behind but since stripping the first i'm been much more careful.
It is currently secured with a couple of zip ties and a length of inner tube but i'd like to get it fixed.
Can anyone suggest a suitable repair? Rivnut?
Re: Tank / Fairing fixings
uglybassplayer wrote:Can anyone suggest a suitable repair?
Yep very common problem, mine was toast on my old tank but the replacement tank had good thread thankfully. :hot:
Old shagged tank.
And the replacement (before sandblasing)
After sandblasting.
I would simply just over tap the thread, so i think from memory they are 6mm? go 8mm, you could just weld new nuts on but that means draining the tank & filling with water (no explosions)
I personally hate all these bodge fixes on the market (nutsert & helicoils) they never last.
ferzz
What Bike or Bikes Do You Own?: XTZ 750 ADV-Ténéré RetroRaid
XTZ 660 original Marathon 1994 Motor-France
XT 600 Z replica Marathon 1990 Motor-France
MuZ Baghira original Paris-Dakar 1998 Nº 17 Marc Morales Team Challenge 95
Post by ferzz »
With epoxy I glued a nut in. Longs fantastic.
Cheers Boris
-> RetroRaid - rally touring parts
Matt-Tenere
What Bike or Bikes Do You Own?: Yamaha Tenere 600 3AJ '89, Cagiva Elefant 900ie x2,E900,Beta 300 RR ,Yamaha Tenere 1VJ, Husqvarna CR 250 '76 twinshock
Previously Owned Bikes: Various motocross bikes ranging from 1975-2003,all the Jap brands.Enduro bikes also,Husaberg 450,Husqvarna 360, Italian TM's were a favourite.Road/trail bikes including 3 Yam Tenere 600 over the years,MTX 200,Aprillia RX 125,DRZ 400,DR 350s...
Post by Matt-Tenere »
Chimney nuts-either the slip on or the rivet on types.The rivet on can be fitted using countersunk rivets and then the lug stays the same height or the easier slip on. Pro bolt do them both but ebay will be cheaper.
Matt-Tenere wrote:Chimney nuts-either the slip on or the rivet on types.The rivet on can be fitted using countersunk rivets and then the lug stays the same height or the easier slip on. Pro bolt do them both but ebay will be cheaper.
Very good idea, buy that man a pint. :beer:
uglybassplayer
Great, thanks!
They're 5mm, easy to tap out to 6mm Mez
GeoffD wrote:They're 5mm, easy to tap out to 6mm Mez
Now you remind me of course :headslap: i know remember scratching around for 5mm in my box-o-shite, the only oddball size on the bike.
