xt600 e engine fit a 1VJ/3AJ
hi anybody know if a XT600 e engine will fit into a 1VJ/3AJ frame?
I know the earlier kick start only engines won't fit
charliext1vj
Re: xt600 e engine fit a 1VJ/3AJ
Post by charliext1vj »
seen it in use regularly so yes! I think Bob said a change in swinging are spacers and obviously clutch cable was about the main of it. Have that job to do myself so a detailed photoshoot would be great!
Just read through Geoffs rebuilds, im sure he has put a 3TB in both his 1VJ & another of his 3AJ`s.
Just remember you will need the wiring loom/ign switch etc & also remember a 3TB is TCI not CDI so you will need that also.
As NASA are famous for saying.....
'Given sufficient time and money, we can do anything!' :star:
'e' engine will not easily fit into the 1VJ, but it will be more easy to put in 3AJ.
I've bought the motor now, it's from a 1992 so let the fun commence.
Picking it up tomorrow so I'll try and get the electrics TCI etc. If it's a nightmare I can always move it on :wave:
charliext1vj
please document the transition really keen to learn your lessons
I have the stator, flywheel and electrical gubbins from the original 1VJ motor.
Simple question, can these parts replace the 3TB stator and flywheel letting me use the original wiring, stator and CDI?
2001 KTM 300XC
Post by scottieh »
The flywheel should mount to the crank since the 3tb crank is what i am using on my own 1vj/3aj hybrid.
I suppose the next question is whether the stator and pickups will mount inside the case cover and if the wires will route correctly outside the case.
I'm sure someone on here has done that, used the old cover/stator/flywheel and wiring.........
jibber wrote: Thu Jun 13, 2019 6:16 am I'm sure someone on here has done that, used the old cover/stator/flywheel and wiring.........
I was thinking the same, wiring was a right mess from memory? :scratch:
