Source coil question on Red and Brown wires
Anything Electrical
Noely
What Bike or Bikes Do You Own?: 5th - 1988 XT600Z
Thanks to Mezo
TT350 1990
XT600Z 88, another complete one.
Previously Owned Bikes: 1st - 1975 XL 250
2nd - 1982 XT250
3rd - 1984 XT600
4th - 1986 XT600Z
Post by Noely »
Hi all, :nannawave: Tenere not going due to no spark. :bag: Bike has done 7,000km's since rebuild. :oilleak: I had put a Ohms meter on the Red & Brown wires and no reading. :scratch: Manual reads that there should be 160 to 240 Ohms. :rtfi: So with no reading from the meter what could've happened inside of the left hand side cover? :dunno: Broken wires? I'm not sure, any help would be greatly appreciated. Thanks guys :yess:
JamesinEdinburgh
What Bike or Bikes Do You Own?: 3AJ, T7 & ST
Previously Owned Bikes: 1VJ, 3AJ, PE400, PE250, PE175, DT400, DT250, SP370, Z1B, XS1100
Re: Source coil question on Red and Brown wires
Post by JamesinEdinburgh »
I'm pulling my hair out at no spark as well (and rapidly running out of lager in in my garage as I check one wire after the other in response to threads here)
I had to buy a new multimeter as the old one was giving weird readings.
My readings after 10 years of inactivity are within the range specified so perhaps you might want to double check your procedure.
My horn doesn't work any more which leads my to realise that 'Corrosion Happens'. Perhaps that's what happened to your coil?
PS: If anyone knows how to check the readings on a 3aj CDI unit, please lete know in a dm to keep this request clean.
James
Noely
Thanks to Mezo
TT350 1990
2nd - 1982 XT250
3rd - 1984 XT600
4th - 1986 XT600Z
Post by Noely »
Hi James, I found with my 3AJ that once the ignition is turned on the horn has voltage to it. Hence i've wired some accessories to it. At the moment I've put the bike to one side just because of my work load.
To Be Continued!
Hi there,
my book states there should be 112-132 Ohm between red and brown, for a 1987 Tenere (1VJ). However, there should be SOME resistance there, else the coil will not work.
Broken wire sounds about right. If you are lucky it is just a faulty connector/Cable OUTSIDE the engine cover, where did you measure? You can undo the spades from the connector to check for bad soldering or broken cable.
