Hi Member here!
I've been lucky to pick up a 2002 600 e with UNDER 4000mlies.
I've changed oil and filter, new front tyre (side walls perished) and fitted a gpr end can as original had rotted at the join from the header. All was going well until coming home from work today in terrentail rain. After a run up to 65 mph pull up at a junction as I pull away engine splutters and dies on busy duel carrage way. After a 5 minute push try to start it and seems OK. Obviously water is getting in somewhere what's the best tips for waterproofing the electrics as I have bought the bike as my winter/wet weather ride.
I removed the seat and took battery out to have a look and noticed the starter solenoid was hanging in thin air. The rubber holder has perished and broke. I've searched the net but can't find a replacement, only seem to find new solenoids in the holder not separate holders. Any ideas? Should be able to bodge up something using bits of inner tube and cable ties but would prefer the proper part or equivalent.
Apart from this issue am enjoying having a single back in my life. I'm enjoying the winter rides and saving my other steed for the spring .
