1vj gearbox problems
hambone
What Bike or Bikes Do You Own?: 1986 xt600 tenere 1vj cbr600 1994
Previously Owned Bikes: tomany to list
Post by hambone »
heiio all i am new to the forum. i have a problem with the gearbox sprocket shaft. Half of the splines have worn off and 2 and 3 gears are pitted quite badly. So will another gear cluster fit say from an xt600 grizly [ i dont know what one is but its on ebay] or a 1989 bike. i am well stuck at the moment thanks for any help. hambone.
Re: 1vj gearbox problems
Later 3TB boxes are a popular choice and available on e bay esp cheep in the US, just make sure you buying a good one.
Late 3AJ would be the best one, if it already has that external oil line outside the engine. Still CDI then.
I think he wants a box not the whole block
Ah ok - languare issues then. Sorry.
hambone
Post by hambone »
Hi thanks for replys. I found a gear cluster on usa ebay from a yam grizzly atv i think so risked it would fit and ordered it. the very expensive custom fees of the uk put the price to £230 oh that was also with the later oil pump. anyway the parts arrived they are like brand new no pitting its the later output shaft so has the nut and washer gearbox sprocket so looks good.Am going to start biulding engine up this morning as have been side tracked with powder coating frame/rebiulding wheels etc. hoping i dont come up against any problems. so again thanks for replys.hambone.
dzl
Post by dzl »
I have a feeling the 3TB trans output shaft is slightly longer. This would cause your counter sprocket to be misaligned with rear sprocket. Think this is the issue when installing a 3TB engine into the earlier drum brake rear XT's....but I may be wrong and will all fit no worries!
See here what was done to fit 3TB engine into a 34L regarding the counter sprocket mod he performed. May assist you if have same issue?
http://www.horizonsunlimited.com/hubb/y ... swap-52069
Kick only cases were narrower
hambone
Post by hambone »
Hi all. Update on gearbox marathon. So got the later gear cluster fitted biult up the crankcase halves came to clutch and the center boss is different it has six splines on 1vj and 12 splines on the later engine. So bought a boss from a guy in australia wich came yesterday. today is biulding day. Have seen a post on here that says output shaft is longer than 1vj mine looks a tad short.have had a straight edge on sprockets and it could do with mybe 3mm further out. am going to see how it develops. Just one other thing when rebiulding top end the gudgeon pin seemed to have a fair bit of rock on it i thought it was little end bush wear but is no bush. so have carried on regardless will find out when it stasts up. to be honest could not face a cranck rebuild at moment. So bye for now hambone.
sounds like the little ends shagged, the problem is, when you open up one of these older motors you can be opening a can of worms. Count the teeth on the gear at back of the clutch.
