Ok, fork rebuild time. I had a look at the bottom bush and the copper surface was worn quite badly, so it needed replacement.
Onto the parts fiche and the replacement part = 34L-23171-00 x 2. Small problem in that they are showing as no longer available.
I searched for the same part number but for the 55W and this showed that there were still some available, so I ordered a pair and awaited their delivery.
When they turned up this morning I went into the garage to check they fitted but to my dismay they were very different - see below:
They are an identical diameter but the 55W part is about 3/4 the depth of the 34L part. Why would they change the parts so dramatically between the two models when there appears to be very little difference in the function of the fork?
Does anybody know if there are any alternatives?
I have searched the interweb high and low and from my searching I can't find the 34L part anywhere. I have tried a 43F fiche but can't even see a similar part listed.
What part does this bush play? Is it vital? (I know that's a daft question but I am getting frustrated at being held up). Could the shallower part be used without any reprocussions?
Any help would be greatly appreciated.
