Neutral Switch
coots
What Bike or Bikes Do You Own?: 91 XT600e
Neutral Switch
Post by coots »
Took my 90 XT600E out for a few miles yesterday, stopped to see a friend, got back on, fired her up and the Green Neutral Light stayed on :wtf: So now I am in Neutral in every gear. Could it be that the switch just went tits up? Any ideas?
Neutral Switch
Try unpluging it from the wiring loom first to test, but id sounds like the switch.
Hope its nit like the DR's? when the screw falls out inside the engine.
coots
Re: Neutral Switch
Post by coots »
It is just one wire on the switch, I took it off but the light was still the same. Does that sound right Mezo?
Re: Neutral Switch
So its using the ground of the engine (like a negative) so know is the question is it normally closed or normally open switch.
Are you able to ground the wire in the loom to the bikes frame (earth if you will) with a small bit of wire & see if the light goes out, hope you understand what i mean? put a bit of wire or metal in the connector on the loom side not the switch & touch the other end of the wire to negative.
You should also be able to use a multimeter set on continuity & put one end in the connector going to the switch & again the other touching ground, try selecting a gear & neutral & see if the meter changes.
stu400
What Bike or Bikes Do You Own?: xt600 43f 1984
Moto Guzzi griso 1100
Previously Owned Bikes: Honda CB900f hornet 2002
Honda CB400f 1976
Suzuki SV650 2001
Re: Neutral Switch
Post by stu400 »
The switch is normally open, so if you ground the wire the light will come on. The problem on mine was the loop terminal on the end of the wire was large enough to touch the inner and outer parts of the switch so the circuit was always complete. Once I put a small looped connector on it was fine.
good luck
