Danjets Honda Transalp
Re: Danjets Honda Transalp
Nice one, same here im glad you never started yanking the heads off.
Danjet600
- Founding Member
- What Bike or Bikes Do You Own?: xt600e 1991 ex australian army
ok a little premature with celebrations it seems i also have the dredded CDI problem, it fires randomly, but now with the wire fixed it behaves as stated in the threads i have read, the tacho dosn't work when the CDI's are swapped, so new CDI's will be ordered, for now i'm trying the home repair by resoldering the circuit board in the cdi, works for some people, one bloke soldered the circuit board then hard wired the CDI's to the harness
, no further problems for him so far
Murray Walker
Murray Walker
Look for cracked or dry joints Danny, just touch your iron on them & the existing solder will join again.
- Founding Member
I would recommend also adding some fresh flux cored solder or else you wont get a nice "wet" joint.MEZO wrote:Look for cracked or dry joints Danny, just touch your iron on them & the existing solder will join again.
Danjet600
- Founding Member
just went and got one of theseActionManMelb wrote:I would recommend also adding some fresh flux cored solder or else you wont get a nice "wet" joint.MEZO wrote:Look for cracked or dry joints Danny, just touch your iron on them & the existing solder will join again.
http://www.jaycar.com.au/ShowLargephoto ... ME=20/130W Soldering Iron Starter Kit&IMAGE=
now i can suck out the old solder and redo all the joints
hope it worksI don't make mistakes. I make prophecies which immediately turn out to be wrong.
Murray Walker
Murray Walker
Yep they work very well "solder suckers" they also work well on spots/zits blackheads etc.
- Founding Member
Yeah, and don't get the trouser python caught in the industrial sized model.
Danjet600
- Founding Member
and where do you purchase these industrial sized models?ActionManMelb wrote:Yeah, and don't get the trouser python caught in the industrial sized model.
this is the before my resoldering job
and after
went a bit crazy and bulked up the solder but fuck me it works
firing on both cylinders and tacho works with CDI's in any position, now I've got to seal the circuit board with some resin or something any idea's??
Murray Walker
Murray Walker
- Dirtybrit
- What Bike or Bikes Do You Own?: 1982 XT 550, 1981 YZ250, 2010 Triumph Tiger 1050, 1981 XR 200
- Previously Owned Bikes: Honda SS50, Yamaha RD2501973, Honda XL125, Yamaha DT175, Kawasaki KE175, Yamaha YZ250D, CT90, Suzuki RM400, Yamaha YZ250H, 1981 Yamaha RD250,1982 XT 550, 1979 XS 750, 1979 YZ 400 F.
Try using the stuff you get out of the industrial sized sucker!
Danjet600
- Founding Member
Dirtybrit wrote:Try using the stuff you get out of the industrial sized sucker!
well i end up using some araldite, should be protected now
the location of the CDI's in the early models are verticle and the seat pushes down on the plugs and causes problems
in the later models they mounted them sideways, so i copied the setup
some progress was happening
i got to the point of starting it up and had some success, but was misfiring a bit and seemed really rich, i adjusted the carbs tried everything still no joy so left it for the night, next day went to see if it would start and it wouldn't turn over
so i pulled the spark plugs and found no.1 full of fuel
refitted carbs went through the final checks, water yes ,oil??
so i've drained the motor oil/fuel out took off the oil filter and left the sump bung and oil filler plug out hoping all the petrol will evaporate, is there anything else i should do? i'm thinking fill it with cheap oil get it hot and drop it out? thats if it runs
Murray Walker
Murray Walker
