Just putting things back on the bike; 1VJ
There is a connector to the positive and one to the negative terminal. Negative is spliced into the main negative lead; looks very genuine.
But... the lead going to the positive terminal.... first it is black... then it goes to a chocalate block with two blacks coming out!....
Vague like I said....
Okay, if I connect an ohmmeter to that lead going to the positive terminal, I get approx 78 ohm to any earth point.
Before I rebuild the carbs and start it etc. any ideas what this might be, or how to check what it might be?
John
